I assume my power steering assembly is the reason there is no fan connected to the front of my block. I have a multi belt system and if there were a fan there it would only get in the way. However, i have a dual fan setup attached to the radiator which shorted out during the original overheat when it spilled all over my driveway. assuming the current wiring for the fan is correct all i need for the radiator fans to run again may be...
http://www.summitracing.com/parts/HDA-3653/
