Unless the water pump is leaking I'll bet money it's not bad. I have never seen a water pump rust the impellers off.
CHANGE THE THERMOSTAT FIRST! This is a cheap fix. If the stat is stuck, the water pump is not circulating water to the radiator.
He never said if it was leaking or not, probally never looked close enough to know.
If it ain't leaking, it's working. lol Like you said.
Too bad our government won't fix our cars yet.
