Power steering would not be a reason not to have a fan on the motor. The fan would stick into the shroud to where it would only be an couple of inches away from the radiator which would put it way out in front of the power steering. bThere will be either a clutch on the fan or a spacer between it and the pulley ythat will move it forward away from the belts.
