its like a 5 sec experiment i didnt go anywhere before i did it.
take the radiator cap off before you turn the car on, after you did that, drop a string down the rabbit hole, make sure you hold on we don't want alice to get lost again. and if it moves or is getting pulled in then my water pump is broken.
thanks fellas. sorry for the double post im poor and if i can waste your bandwith instead of my money by golly i will.
