Unless the water pump is leaking I'll bet money it's not bad. I have never seen a water pump rust the impellers off.
CHANGE THE THERMOSTAT FIRST! This is a cheap fix. If the stat is stuck, the water pump is not circulating water to the radiator.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
