Big compression does wonders for the heads you mention ! I know you wanna stay on pump fuel also!
The comp will be either 10.5:1 - 11:1. Im not going to go higher than that because pump gas is a must are you talking higher than 11:1?
Im sure it will be fine and I will be close to 600hp it will come down to dialing it in on the track to get the #s out of it.
Don
Street/Strip 73 Barracuda
