Thank you for serving
and your combo is VERY similar to mine too . I would do a roller cam if you can
ive battled real bad weather and gremlins this year , but i know this thing will go at least 10.30's or 6.50 1/8th or so ...
it did turn a 1.411 60' recently . and a 10.40 last may. But we have had brutal humidity/weather from may thru sept. here !
Get a good converter 4-5k and good rear shocks off the top of my head . And call Hughes Engines if you are trying to pick out a certain cam-- they are a great help and mopar only
