Shocker, they are working well if you have no spin off the line. Might require some better shocks down the road to expand the range of hp and torque they can control. I wouldn't worry too much about those that want to pick apart what you are doing. Just refine your data recording for your own purpose, keep an eye on what out there works, and how. With enough shock control and travel, combined with front suspension tuning, you might not need to upgrade till you need a full cage! I
