hey bob i run .900 lift and .260 valve to valve,,,, ma mopar must have missed the boat on me.... the mopar jury must not apply to me..
do not go on assumption.... check your actual clearance with springs, lash up through the bottom of the cylinder,, if you have .025 run it
and pretty much noone runs .300 valve to valve anymore,, unless you are running a 426 with a cam from 1970
Priceless info right there!!I would never have thought......
HEMI-ITIS has no cure. My condition is fully BLOWN!!
