Before getting too excited about them hitting i would set the valves up with the intended springs you are going to use, set with lash and then check again (going the correct direction). There will be a bit of deflection in the pushrods and the rest of valvetrain, big cams are a lot of times real close on valves missing each other, but if you do have to adjust i would cut the exhaust valve down slightly.
93 Dodge Stealth - Supercharged 526ci Hemi 93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS 67 Hemi GTX (may the 4speed with you!)
