Yea..install the actual springs, set zero lash, pull your pistons and rods, leave the crank, assemble and install both heads on the block.
Now confirm actual v-v clearance with a feeler gauge up reaching through the bottom.
I dont think I need too...I know they need work..The Mopar Jury has reached a decision. If I had .280 between the valves yea..maybe...But Im almost .050 from recommended minimal valve to valve clearance LOL
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
