Hey Guys,
Sure fit way to do this is. Take some rect. tubing (taller than the tallest demension needed), Measure the narrowest dimension (at the rear attachment pt.) level & attach the tube that same amount off the floor pan. Lets say it's 2". Mark the tube at the front 2" off the bottom edge. Now take a compass (for drawing circles) & starting at the rear of the pan, run the pointed tip against the pan & the pecil on your tube. Do this to the front of the pan & you will have a line that matches the floor pan perfectly. You have to make sure that the compass stays perpendicular to the tube, or the line won't be consistent. Cut on the line with a jig saw or plasma & you're go-to-go.
