Quote:I remember from some Keisler threads that there were two different floor pans for 70 E-bodies. Is that correct? BUT it sounds like the edges are close, but just not close enough. Your floor pans are all orginal I assume too? I wonder if factory tolerances are just to variable to get things to line up perfect with a pre cut connector.
