timing is now at 35 total 16 base. Idles at 1000 out of gear 850 in gear. Does not load up anymore at stop signs. vacuum is at 8-9 bouncing around out of gear around 5-6 in gear.
Idle mix screws are 1 turn out and if I hit the squirter idling the car dies.
