At 1st I cut out the shock tower leaving the shock mount hole intact and welded 2 tabs to the underside of the shock mount for bolting the shock in.When I had the "J" bars installed it made sense move the shockmount to the j bars. If I didn't do something with the shock tower then I would have to drop the shock to get the Valve cover offf.
HEMI-ITIS has no cure. My condition is fully BLOWN!!
