Gonna completely rebuild the front suspension using a tubular K, complete all the mods needed and strip and paint the engine bay body color, all but the firewall. I'm told I should space the K from the frame as well, but not sure how much spacer is needed for that. Some used 1/4" some 1/2", not sure what is really needed there.
If you are using a tubular K-member I don't think you need to space it down at all. When they developed the Hemi A-bodies they said they did that to get room for the air horns.
