I was thinking about that, was also thinking about starting with the existing VB and pop the new solenoid and transducer in and see if it solves the problem with the computer wanting so much gov pressure once I exceed a certain speed.
I got a 3rd VB here, from a guy in another forum that he said was for my year but has the older style of governor sensor/transducer. Supposed to be a fresh rebuild with new solenoids but they won't work for 00 and up. (Mine is 01)
What problems are you having?
Also you refer to the computer wanting so much gov pressure. What do you mean here ?
