Why do you need to loop the trans lines if the trans doesn't pump in park? Just curious. But if you fill the trans you will need to plug the tail shaft.
It can still move enough fluid to make a mess. Looping the cooler inlet and outlet is just a good precaution.
Along with sticking a plug, or yoke, in the end of the trans .
