Mr. OP. At this point I think wed rather see you make a vid of you pouring rocks down the carb. Your obsessiveness over this guy vs the actual carb is obvious. Stop crying and just get a different carb that you had sorted out thats now not sorted out and move the XXXX on.
Originally Posted by dart games
so im trying to make sure when i take out the car theres no problems.still having problems with doms carb.so hope carb gurus and chime in on this one.still idles great and rpm dont come down when put into gear.promblem is both primary and sendondary sticks and wont come back down to idle.you have to move it to come down.but when shut off throttle works great and dont stick.only does it running.as said in the past i drilled holes in te blades.so i took carb off and rivet the holes .made no differance.should i make a vid of me throwing doms carb in the trash or keep trying to fix his carb or find another carb
