i know a guy had an all aluminum indy engine in dragster . he couldnt get it to idle pulled the heads off took them to reputable machine shop had a pressure check ran well the heads didnt pass the pressure check for roller springs he installed heard back on engine and got it to idle . it may not be your problem but run a compression check on each cylinder with plugs out all cylinders should be within 10 lbs of eachother
