SO THIS IS WHAT I BOUGHT.WAS GOING TO USE THE MOTOR IN THE DRAG CAR AND TRANS IN MY STREET CAR,AFTER HAVING PROBLEMS I LOOKED UP THE CAM # 23-000-9.TO LOOK UP WHAT THE VALVES SHOULD BE SET AT.RIGHT NOW WHAT THEY SET IT AT IS 0.15 INTAKE ,020 EXHAUST.ONLY THING I CAN FIND OUT ON CAM NUMBER IS ITS A CAM CORE.SO MUST BE A CUS511 Low Deck Stroker Engine (estimated 650 to 700 HP on Pump Gas): Built 727 Transmission (New Dynamic 9.5 inch street/strip Converter):
This is a brand new / turn key engine (never been fired). Machine work and short block done by Precision Engines in Granite City, IL. Why am I selling it? I built this engine to go in a 69 Satelite to be a street/strip car. Before I finished the build I found a good deal on a Hellcat engine, lost my mind and pulled this engine and trans to do a Hellcat conversion.
Engine Details: - 400 Cold Weather 230 Block (.030 overbore) - This is strongest Mopar production block, very hard to come by as they only made them in the summer of 1971. - Molnar Forged Crank and Rods - Ross Pistons (10.5 to 1 Compression for pump gas) - TRICK FLOW 270 HEADS!! (very hard to find right now) flow 353 cfm on the intake at .700 inch lift. - Comp Solid Roller Cam and lifters( see picture for specs) - Smith Push Rods - Harland Sharp Roller Rocker Arm (1.5 ratio) - Indy Max Wedge Port Intake (4500 flange) - ATI Harmonic Balancer - 1020 Holley Dominiator Carb Built by Dominic at Thumper Carbs (Dominic is know for building Dominator's that run well on the street and strip) - BLP Racing Fuel Log - MSD Billet Distributor - Taylor 9MM Fire Power Spark Plug Wires - All new or rebuilt front accessories ( has a single serpentine belt running all accessories including Power Steering Pump) - Electric Water Pump - Hooker Super Comp Headers (For 69 Mopar B Body Chasis). These are uncoated/painted black. - Milodon Oil Pan
Transmission: - Professionally built by Bob Brooks - AA Transmission Reverse Manual Valve Body with Low Band Apply - Billet Steel Drum - Hardened Pump Gears - AA Trans 6-bolt Ultimate Sprag - All other parts are high end and heavy duty parts build to withstand 700 HP. - Frank Lupo's Dynamic Converter: 9.5 Inch RACE/STREET. 3500 to 6500 RPM Stahl TOM GRIND..........
