so this is the engine and specs i bought from a local mopar person.cant find any info on the cam.email comp cams.heard nothing.that customer service sucks,thumper offers no turning advise.that customer service sucks.moal of the story.never buy a engine unless it wasw dynoed or you can here it running.if you do.spend a few hundred bucks and tear it down and check someones work.......................... - 400 Cold Weather 230 Block (.030 overbore) - This is strongest Mopar production block, very hard to come by as they only made them in the summer of 1971. - Molnar Forged Crank and Rods - Ross Pistons (10.5 to 1 Compression for pump gas) - TRICK FLOW 270 HEADS!! (very hard to find right now) flow 353 cfm on the intake at .700 inch lift. - Comp Solid Roller Cam and lifters( see picture for specs) - Smith Push Rods - Harland Sharp Roller Rocker Arm (1.5 ratio) - Indy Max Wedge Port Intake (4500 flange) - ATI Harmonic Balancer - 1020 Holley Dominiator Carb Built by Dominic at Thumper Carbs (Dominic is know for building Dominator's that run well on the street and strip) - BLP Racing Fuel Log - MSD Billet Distributor - Taylor 9MM Fire Power Spark Plug Wires - All new or rebuilt front accessories ( has a single serpentine belt running all accessories including Power Steering Pump) - Electric Water Pump - Hooker Super Comp Headers (For 69 Mopar B Body Chasis). These are uncoated/painted black. - Milodon Oil Pan
