Plugging the power valve probably won't help; That adds more fuel to the main well. The idle an transitions have down stream restrictions. The easiest try to see if your idle is lean, beyond turning out the mixture screws,is plug or cover the idle bleeds and see what it does.If that stops the red hot headers, then you know its in the idle/transition circuit.
