MikeE,you may want to try lowering the float level in the center carb.You may not have noticed but the sight plug sits approximatly 1/4" higher on the center bowl.If you adjust so fuel just trickles with sight plug removed as recommended,the center carb will have a higher fuel level that the ends.
