I have same problem with my AVS 4bbl on 440 Charger, but it will also stall on hard left turns but hard right turns are no problem. (this is with foot off gas pedal). Setting float level low seems to help but no solve the problem.
There is a fix for that in the old Tech Bullitens.If I can find it I'll post it.
