Originally Posted by Pool Fixer
Originally Posted by terzmo
Runs well at timming submitted. No external trans cooler. Mild converter 2800-3200 stall. I ordered the flow cool pump and high flow thermostat.
The flowkooler is for sure very different than a stock style pump. Many more smaller straight vanes on it. I chose it because I'm running a serpentine setup that turns the water pump in opposite direction than stock.
if you end going with electric fans, be careful what you choose. Seems like the CFM ratings they claim are optimistic at best. for example, I run spal 12" fans. rated at 1360cfm each. draws 18 amps. Derale makes a 12" 2000 cfm fan that draws 24 amps. then you go look at some other 12" fans that ive never heard of before.... they claim to move 2000 cfm and draw 9 amps? Even if they had some miracle design, I can't see them outflowing mine by 68% at 50% less amp draw... at 40% of the price to boot! come on!
Yes
