Originally Posted by 360view
It should be on IC engine owners “Bucket List” to run
100% water
50/50 coolant
0% water propylene glycol
From my engineering days:
I can tell you 100% water cools better but is prone to corroding and freezing ( DUH) wink
50/50 has a higher boiling point, doesn't freeze except in EXTREME temps
100% propylene glycol will not cool as well but will lower the freezing point
smile
