I attached some pictures of the converter that I removed. The weight I am referring to is the small rectangular tab welded to the outer shell. I assumed that it was there to balance the converter, but perhaps it has some other purpose. Yes the engine is internally balanced and the converter is a 764 Mopar unit that is correct for an internally balanced engine.
