Alright, thanks for the feedback everyone!
In hindsight I should have gone with a 2.05" valve to start off with and a real valve job as opposed to leaving these as they were.
I am in a bit of a pickel now b/c my valvetrain geometry kit uses the current 2.02" valve size and going to a bigger valve now would negate the fit of that kit.
I will look around to see if I can find the same length valve though, but not likely...LOL
In the meantime, the current flow bench guy who suggested that I should really do a valve job says the following:
- 4 angle job
- blend in to a 3 angle after
- do a backcut on the intake valves
So that'll be the plan for now. I'll update with the new flow results as we finish that work.
If you stay with the same length valve your geometry kit won’t be affected. Go for it. Personally I would go 2.08 but that’s me.
