Alright, thanks for the feedback everyone!
In hindsight I should have gone with a 2.05" valve to start off with and a real valve job as opposed to leaving these as they were.
I am in a bit of a pickel now b/c my valvetrain geometry kit uses the current 2.02" valve size and going to a bigger valve now would negate the fit of that kit.
I will look around to see if I can find the same length valve though, but not likely...LOL
In the meantime, the current flow bench guy who suggested that I should really do a valve job says the following:
- 4 angle job
- blend in to a 3 angle after
- do a backcut on the intake valves
So that'll be the plan for now. I'll update with the new flow results as we finish that work.
