Ok . . . so maybe I am the outlier here . . . I have the FACTORY batteries in my 2002 Cummins ! Both still show the 'green" eye, and test good ! . . . I have always made sure to check the fluid level and top up with distilled water. Also, have had battery maintainer on then when I am not driving the truck. I generally only use the truck in the spring/summer/fall, and even then it is for towing the travel trailer or the car trailer . . . it sits with the battery maintainer on there - I do check to make sure all is good, and have changed battery maintainers over the years. I also have the factory battery in my 2004 Crossfire & 2006 Magnum. Yup, when not in use, I put battery maintainer on them.
So, 20 years from original batteries . . . never heard of, but I can prove it can be done !
Like anything, it is how it gets utilized, maintained . . . figure if I can pop caps off to check fluid level, then I check it !
Best of luck to all !
Cheers
