Any pic's of the bearing half. They are softer so consequently show more about what may have been going through the motor. The only way to properly check the bottom of the lifter is with a small staight edge, centered on the bottom, and looking up at a light. The center of the lifter should be the high spot. It's not much of a crown but should be visible using the above method
