i would still yank the intake and make sure that plug at the back of the drivers side lifter galley isn't missing. never the less the bottom end is bad. looks like trash ran thru the engine or it was put together dirty. too much rpm with half groove mains and low oil pressure/supply ain't good. if the cylinder bores aren't wrecked i'd just clean the bottom end good, ring and bearing, and drive it some more.
