I can see using a solid roller lifter on a hyd roller cam as sort of a “band-aid” for someone who’s trying to remedy a bad situation they’re going through with HR lifters.........like in jungs case.
But....... starting from scratch for a combo that will see pretty limited use? Just give me the SR cam to go with the SR lifters.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
