Originally Posted by AndyF
Originally Posted by Blusmbl
The Rev N Nator is a replacement MP style ECU that requires the magnetic pickup distributor to work, the Holley won't be able to control it unfortunately if you're looking to control timing from the Holley.
I'm researching this stuff myself, I already have a 6AL and Blaster II coil, was going to use the points output from the Holley to drive the MSD box. If I were you since you need to replace everything and already bought the Hyperspark distributor, I'd buy the matching Hyperspark CDI box and coil. You won't have a ballast resistor in line with the 12v feed to the coil anymore.
https://www.holley.com/products/fue...er_efi/hyperspark_ignition/parts/556-151
https://www.holley.com/products/fue...er_efi/hyperspark_ignition/parts/556-152
I agree with that. If you already have MSD stuff then keep it but if you're buying new then I'd go with the Holley Hyperspark ignition box. The MSD boxes cost more because they have extra features such as rev limiter chips but you don't need any of that stuff when you are using the Sniper since it is all built in.
Ok I’ll buy the Holley stuff. Any recommendations for spark plugs with this set up and I’m done with this thread. Thanks to everyone for the help.
