The higher the tank-mounted pump pressure (modern factory FI is 43.5 psi, or 3 bar), the smaller the feed line can be. As pressure increases, flow through a fixed line ID increases as the square root of the change. Double the psi raises the flow by 41% (2^.5 = 1.414).
