My small , 440RB , 10.75:1 , 9 1/2" 5000 stall , 4.1 gear , 28" Pro Bracket radial , solid flat tappett , 0.520 lift / 258@050 , CNC stealths ,HP1000 holley , Victor 440 ,1 7/8 hooker headers+ exhaust to diff , pump gas . Best of 10.88@125ish mostly 10.90s. 3690lbs 68 Satellite .
Same short motor , TF270 , Super Victor , 4500 1050 , 30" Pro bracket radial , 6000 stall *" , 10.70@127ish.
Went to 2" Dougs D452 with the 505 and used them on the 440/TF270 motor .
505RB with 11:1 , same top end as 440 (Stealth / HP1000) , solid flat tappet .600 nett lift 272@050 ,10.50@127ish , 28" radial
505 with TF270, 4500 etc 10.25@129ish
Then split block
Heck i went 11.20(?) with a 509 cam in that 440
This is my daily driver , in fact i am driving it interstate in a couple weeks to race . 11/12 hrs 1050kilometers(650 miles) each way
Tex
