The M1 will work but if you have the room a Trick Flow intake will work better. Do some research on EFI before you start spending money. EFI will solve a bunch of problems with street/strip cars but it takes money and some knowledge to make it work. Putting the fuel pump in the tank with the regulator simplifies the fuel system. You'll only need one high pressure fuel line and no return lines. Having the EFI system control the ignition timing gives you complete control of the ignition timing which really helps when you have a big cam on the street. Plus, these systems come with data logging built in which helps debug any problems. It is one of the big changes over the past 10 years but is still fairly early in adoption phase.
