Your recipe should get you to where you want to be, as long as the chassis is up to the task, with room to spare. My Satellite sits right where you want to be with CNC’d Stealths and a mid-sized solid flat tappet. 28” tires and 4.10’s work real well together, should have you at about 6400 at the stripe depending on your converter.
I would think TF240’s and a solid roller in the range of 250-256 at .050 on the intake side really should have you knocking on the 10 second door, if not barging right through it.
