From my perspective fast68's original recommendation was applicable to the conical spring and not the 26056
I just looked at that again..... you are correct.
I’d be okay with trying the beehives @1.800.
The closed/open loads and distance to coil bind, as well as all the other variables in the valvetrain will remain stable to “x” rpm.
If that’s at a point higher than you need the motor to turn, you’re golden.
If it doesn’t quite go as high as you prefer, you’ll either have to make some changes...... or live with it.
That’s not really any different than any other untried combo of parts.
