Well the shock having issues when compressed is NOT helping for sure. Compression is used to keep the tire planted after initial hit so entirely possible you found the issue. You will find out soon enough. As for Wilwood I was always told to use the square cut o ring, but I have found no matter which you use they will eventually be right back to hanging up again.
