Makes sense. You did say you put new slicks on the car. Were they the same brand and compound that you've run in the past? I've seen 60' times go away when the slicks stop doing their job. A car as fast and violent as your's will likely eat up sidewalls pretty quickly. Sometimes it's good to have a slow race car...like me; ) Still plenty of problems, but certainly cheaper to fix. Good luck. When is your next race?
