Originally Posted by Sniper
Originally Posted by cudaman1969
So tell me what do you use to keep that throw out bearing off the fingers?
You tell use because it sure ain't the over center spring.
Right out of the 70 FSM.
Look again where the spring is attached on both ends. Clutch fork and lower arm of the z bar. It keeps the rod from falling out (been there) and it has nothing to do with keeping the bearing off the clutch fingers. The over center spring does that, like I said the clutch guys say take it out to idiot proof their clutch. Adjust the ratio for less travel and install a stop
