Originally Posted by cudaman1969
Originally Posted by GomangoCuda
Originally Posted by NITROUSN
The only adjustment is on the rod underneath. That is a variable to a lot of people. Most important thing is that the throw out bearing in not spinning when disengaged. As far as a stop there is no adjustment the over center spring pops the pedal back against the rubber stop.
The over center spring should be removed when a diaphragm clutch is used.
Sure like to hear the reasoning for this
Go read John Kunkel's post
