tight valve guides will tear the guides and valve stems up and open up to more clearances than you need, or they will seize the valve and bend them You have another tuning issue or issues I wish I was closer so I could drive it to help you and your Dad. Sometimes the littlest thing will drive you crazy finding and fixing it Don't give up :tsk Keep working on it, you guys can fix it
