Originally Posted by fast68plymouth
Quote
that rocker will be over the nominal ratio so that under LOAD the rocker will have the nominal ratio.
At what load does the rocker go from too much ratio to the “correct” ratio?
You'd be surprised. It does take much. And, once you load the rocker I doesn't change worth more load up to the point of failure.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
