How much cam lift were you losing on the 1.55 rockers instead of the advertised 1.6 rockers.
I'll let you reverse-engineer the answer from the following: .650" net lift w/ .018" lash and .433" lobe
Since you may be mathematically challenged, it's right about .020" net lift.
And how much ET do you think it was costing you in your 3800#, 680 HP street/strip car?
Fixed... and I have no idea since my P O S hasn't made it back to the track w/ the new engine build, nor will the engine go back on the dyno before the car is running again.
How much do you think it would cost you in your... what did Ray call it... oh, yeah... tin can?
