...our similar situation and findings points in the direction of the correction kit is probably the root of the problem...
No, the reason why the Hughes rockers lose ratio with the geometry correction kit is due to the location & angle of the Hughes adjuster screws.
I gave Mike a whole bunch of measurements after doing multiple before & after measurements; Mike worked with someone who does CAD stuff and duplicated my measurements w/in a few thousands of lift. The Hughes rockers are regressive in ratio (start out higher and end up lower); adding the B3RE kit made it more apparent that when the roller-tip geo was changed, it made the pushrod-side issue even more extreme.
This is
not the same thing as I'm asking about regarding T&D rockers, which don't have the same issue when the geometry correction is applied.
Here are Mike's CAD drawings, FWIW.
