Dave, your sweep patterns look far more reasonable than the HS Victor pic I posted above. I wonder if there was a fulcrum distance reduction between the first rockers and yours. The ones I measured were even longer than the Hughes' 1.52". If yours are still off the heads, could you check the distance between the shaft pivot centerline and the roller tip centerline?
