Tire turning more in didn’t happen on the dart. That happens if the rack is to far forward so the tie bars angle back. Then the tie rod tubes go over center, then the tire has to be pulled back. Happens backing up with wheels turned. But I agree 99% should not attempt this but if you do just look at the factory setup on the car you’re getting the rack from then duplicate as close as you can.
